Hello Guys,
i just tried tine20.org, which is use since some years now and found it very genius, sadly i have found one major problem, but at first i want to tell you what works:
private adressbooks
private calendars
shared calendars
but sadly our main shared adressbook isn’t working this way, it’s discovered, but the request to the http endpoint of the addressbook causes an error 500 … the same adressbook is working with caldav sync on android - any idea?
if you need i can add a part of the logfile as well
Hi, can you please make a screenshot of the error you received.
The log file might be helpful as well.
can you please send my an email adress, i do have the log, but would not like to make it available for the public.
later this weekend i can perhaps record the related logfile in tine20 as well …
you can contact me via info (at) .de
Hi, you can send the log to [email protected], please add a reference link to this forum topic.
mail sent (i used tag braces to “encode” my mailadress, so the last part was stripped away)
