emclient 7 print icon
The Print Icon has gone from the task ribbon in emclient 7. Please put it back. Going through the File menu is to long a path.
Hi
When you right-click on the task ribbon you get ‘Customize’ where you can add and remove items.
Hello Dav,
it’s exactly as Georges above mentions, right click the toolbar and click Customize - and add all the buttons to the toolbar that you need.
This is a new feature in version 7.
Right click the tool bar?  My tool bar is under the menu tab.  I right clicked on it, but nothing came up.  Can you explain more?
Thanks!
Right click on the empty space to the right of Refresh and Customise will appear if your emclient is working normally
