Emclient 11 Problems with Office Outlook
After installing emclient 11, I get an error from Office Outlook stating no default email about 3-4 pop ups appear, and eventually I can get outlook to work, I use it for Calendar and to sync with icloud, It did the same in the Beta when I installed it. That time I had to re-install my ssytem to fix the problem, this time I was able to uninstall Emclient 11, uninstall Office 365 as well as Icloud,
installed Emclient 10.4 latest update. Installed Office 365 and Icloud and up and running aghain, any ideas why this is happening, only Emclient 11 causing this proglem
Regards
John
First off make sure you are running the latest eM Client V11.0.1054 Official Release and not any previous Beta. You can download it if you don’t have that from the release history page. Before updating make a manual backup via “Menu / Backup” incase you need to restore for any reason. You can see when the backup os complete in Show Operations via the dropdown on the right of Refresh. Also close eM Client before updating.
If the offical release doesn’t fix it, then see the following threads for help.
Hi John,
Thank you for reporting this. We’re aware of the issue and have published an announcement with more information here: Outlook “no default mail client” message appearing after installing eM Client 11
