eMClient 11 not working with TinyWall
Hi - first time poster here.
2 questions actually - easy one first.
I’ve always used the free version of eMclient and it has always worked well. V11 would not install until I did it manually though. Something about MSI vs MSIX installers…
  1. When I open the program the operation window sits there until I close it. After that it will work as expected (close after operation completes). Is this a known issue? Happened in V10 also.
  2. V11 will not work with my V10 TinyWall settings any more. I use a notifier program called PopPeeper and that connects fine.
If I turn off the firewall it connects. No matter how I set up rules it will not connect if normal protection is on.
It appears there are 2 executables trying to connect. Mailclient.exe and mailclient.Cef.exe.
I do not understand the 2nd one.
My previous rule was to only allow outbound TCP connections to ports 853, 443, 995 and 465. This worked fine. That is secure DNS, HTTPS, POP and SMTP.
Any rule I make for either executable blocks it. Restricted, unrestricted - it does not matter.
Tiny wall does not recognize the .Cef.exe file - does anyone know what it is?
Does anyone know what specific .exe’s are trying to communicate on what ports, in what direction, using what protocols? I think the logs tell me but it clearly is not working. Thanks.
