Just installed eM Client again but it will not load in any emails.
Would probably be happy to buy the pro version if I could get it to work.
Any suggestions thanks?
Any settings I need to check?
martes 26 julio 2022 :: 1309hrs (UTC +01:00)
Hey @MeTheClient
If you need help you will need to give full specific information.
You say you just installed AGAIN
¿Did the previous installation work?
¿Who is your email provider?
¿How did you set the program up?
¿In detail, what settings do you have?
¡Buena suerte!
skybat
