Emails not sent
I have been using emclient for a short while after witching from Outlook 2010, which was not sending or receiving emails due to authentication changes from MS.
It worked initially and was fine, although after a fairly lengthy download of emails etc but thats ok.
However in recent weeks it has stopped sending emails.
I’ve had a look on the forums and have been reading that other people are having this issue, for sometime and emclient has not released a fix yet. Which is a bit disappointing given that other software clients have.
I’m using Outlook & Gmail via IMTP & SMTP, have no errors or messages in the log.
gMail is fine, although I do not use this much.
I was intending on buying a license but this has stopped me as there is no point if the software does not work.
I found these instructions:
https://support.emclient.com/index.php?/Knowledgebase/Article/View/256/7/cannot-send-emails-for-outlookcom-accounts---authentication-aborted
Which I am now following, but I have two questions:
The registry file that is downloaded, what is in it?
Can the instructions not include the changes needed to specific keys?
When will emclient be issuing a fix for this (assuming that MS are not going to)?
Oh, I was also going to check another thing. It has been mentioned to activate air sync, I had this on initially but took it off again (can’t remember why, there was some issue I have forgotten about). It has not resolved the problem.
I would switch to exchange, but have setup for IMTP/SMTP. Am not sure how to switch to exchange, but that would probably mean setting up the account again? So downloading all the emails, rules, calendar info etc?
