emails not sent
I have been using emclient for a short while after witching from Outlook 2010, which was not sending or receiving emails due to authentication changes from MS.
It worked initially and was fine, although after a fairly lengthy download of emails etc but thats ok.
However in recent weeks it has stopped sending emails.
I’ve had a look on the forums and have been reading that other people are having this issue, for sometime and emclient has not released a fix yet. Which is a bit disappointing given that other software clients have.
I’m using Outlook & Gmail via IMTP & SMTP, have no errors or messages in the log.
gMail is fine, although I do not use this much.
I was intending on buying a license but this has stopped me as there is no point if the software does not work.
I found these instructions:
Cannot send emails for Outlook.com accounts - Authentication aborted -…
Sorry, we were unable to generate a preview for this web page, because the following oEmbed / OpenGraph tags could not be found: description, image
Which I am now following, but I have two questions:
The registry file that is downloaded, what is in it?
Can the instructions not include the changes needed to specific keys?
Resending as was pending and then new user restrictions lifted. So posting here and I’ll delete the pending one.
When will emclient be issuing a fix for this (assuming that MS are not going to)?
Oh, I was also going to check another thing. It has been mentioned to activate air sync, I had this on initially but took it off again (can’t remember why, there was some issue I have forgotten about). It has not resolved the problem.
I would switch to exchange, but have setup for IMTP/SMTP. Am not sure how to switch to exchange, but that would probably mean setting up the account again? So downloading all the emails, rules, calendar info etc?
