Emailing from lists/personalised fields
Hi. I sometimes need to send a standard email to up to ten people, but with key fields personalised. Currently I have to create a new email for each one, pasting in the main body of the text and then personalising it with their name etc.
I do have the distribution list and personalisation fields in a spreadsheet, which itself is derived from the Capsule free CRM.
Just wondering if there is anything within EMClient which will enable me to auto populate the individual emails, or even create all of them without all the manual input.
many thanks!
John
If you have a Pro License you can use the Mass Mail feature, which like a mail merge function.
It can only use variables like date and some information from the contact data.
You cannot insert variables from external data.
