When I try to check/sync/load emails usually I get the red triangle popping up next to my email saying “connection failed” and this process will usually take anywhere from 5-15 minutes then I get the red triangle. This has been happening for a while now. I am running Windows 10 and using Outlook. Am up to date on all updates (eClient, Outlook, Windows) and have eClient set as my default email in settings. Any advice to try before deleting my account and reinstalling which I don’t want to do?
Also, is there a setting I can click to NOT sync all my sub-folders each and every time I want to check my inbox? This process is annoying and not necessary constantly. I have a ton of folders and It is time consuming that it goes thru this process every time I just want to check my inbox.
Thanks!
