Email Log in Problem
 I keep getting the attached server says unauthorized message even though my password is correct. When I sign in to Yahoo directly it says it received an unexpected attempt to enter my account from a computer in the UK. I am using a VPN which puts me in the UK. I assume if I sign off the VPN I will be able to use Em but I am wondering is there any other solution to the problem when I am using a VPN.
Hello Peter,
have you tried using the full email address (with the yahoo domain) as your user name?
I will give it a try. Thanks.
I have been having this same problem for days. It is making me crazy.
Is it just when you are using a VPN? I am going to try Olivia’s suggestion and will report back. Don’t get the sever error message when I am not using a VPN.
I tried her suggestion, didn’t work.
what is a VPN?
https://en.wikipedia.org/wiki/Virtual_private_network
Unfortunately both Yahoo and GMail block VPNs (as far as I know you pretty much can’t connect to Yahoo mail from any external app while using VPN) and since this is their security policy, we’re sadly unable to do much. :frowning:
Dave
