eM Client won't start!
When try to start em Client it won’t start and i get no errors. Is there a way to start in “safe mode”?
I forget…i use not the free version. We have 5 licenses bought!
Hi Marcel,
if you are a PRO license user, I suggest using the PRO support system where our support can assist you quickly with your issue, compared to the community forum.
Though I suggest trying to restart your computer and see if eM client starts then, there could be just a different process running that could be blocking it from startup.
Or check the Windows Task Manager and see if there is an eM Client running in Background processes, end it if it does, and then try to open it again.
Solved with update…
