Here’s the error I get when trying to start the program:
eM Client (6.0.24928.0)Windows: Microsoft Windows NT 6.2.9200.0, Framework: 4.0.30319.42000
System.BadImageFormatException: Could not load file or assembly ‘HTMLEditorControl, Version=6.0.24928.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. The module was expected to contain an assembly manifest.
File name: ‘HTMLEditorControl, Version=6.0.24928.0, Culture=neutral, PublicKeyToken=null’
at MailClient.UI.Themes.ThemeSetter.SetThemeForControl(Control control)
at MailClient.UI.Controls.ControlWidgetManager.ControlWidgetManager.insertRemoveButton(Int32 column)
at MailClient.UI.Controls.ControlWidgetManager.ControlWidgetManager.insertColumns(Int32 columncount)
at MailClient.UI.Controls.ControlWidgetManager.ControlWidgetManager…ctor()
at MailClient.UI.Forms.formMain.InitializeComponent()
at MailClient.UI.Forms.formMain…ctor(List1 arguments) at MailClient.Program.CreateMainForm(Boolean startupInit, List
1 args)
at MailClient.Program.Main(String[] args)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Please tell me I haven’t lost all my email!
