em Client won't open
Suddenly can’t get into eM
System.Data.SQLite.SQLiteException: Attempt to write a read-only database
attempt to write a readonly database
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at DbRepair.DbTools.OpenConnection(String fileName)
at DbRepair.Form1.CheckCorruption()
at DbRepair.Form1.Check(Object state)
This error message is referring to your eM’s database. Move your existing database to another location and let eM to create a new one see if the problem elevate. If it works, than something wrong with the database. You can locate your database here:
C:\Users%Current User%\AppData\Roaming\eM Client (Vista/Win7)
C:\Documents and Settings%Current User%\Application Data\eM Client (XP)
Thanks. I’ll keep that in mind. I think the problem may have been caused by my setting my Seagate Backup with Memeo software to backup the eM Client folder. Possibly it and eM Client were conflicting in the use of the database. I stopped the backup and eM Client running good now. If I backup I’ll do it at night when I’m not using eM Client.
