When I opened eM Client this morning I got an error message saying that the ‘All Mail’ folder was disabled and that I needed to make sure it had ‘Show in IMAP’ checked in my Gmail settings. This was strange as it was working absolutely fine yesterday, and I haven’t changed anything since I last used it.
I duly changed the setting in Gmail, and now eM Client won’t open at all. It runs through the whole ‘eM Client was not shut down properly’ repairs, I get the two green ticks and it says it’s starting, then nothing. I’ve uninstalled and reinstalled it – same problem. Can anyone help please? I’m using it on a PC running Windows 10. Thanks.
Thanks. I don’t think anything’s changed overnight. I’ve already unistalled and reinstalled it once this morning, but I’ll try it again with deleting that folder.
I have similar problem. Every time I open eM Client I receive a message Error with red flag : Imap No message no longer exists.
I have the last version : 8.2.1659 (845a639)
If you have already tried removing and re-adding your IMAP account and still getting that same error with the latest version of eM Client which you currently have, I would contact your mailbox server support. Googling around, this error can be related for many peeps to “your actual IMAP mailbox” being no longer available or not available some of the time. Let them know the error you are getting.
Apart from that, if your Mailbox server support say their end is ok, then if you have any eg: optional firewalls, security programs, antivirus programs, vpn’s etc, then try disabling those to test if any of those are the issue.
