Hi, (see end of post for addition edit)
A couple of days ago em Client suddenly started to not connect to Yahoo mail. No incoming mails nor outgoing mails.
I had NOT changed any settings.
The Diagnose tab’s Fix option could not fix the problem.
I have copied the log entries below.
Can anyone help!
Regards
Martin
09:37:55 [email protected] [SMTP] Connecting: To [email protected]
09:37:55 Internet Calendars [Web Calendar] Synchronizing folder ‘Internet Calendars/UK Holidays/’
09:37:55 [email protected] [POP3] Connecting: To [email protected]
09:38:17 [____@Yahoo.co.uk](mailto: ____ @Yahoo.co.uk) [SMTP] MailClient.Accounts.SocketException: Connection failed due to the following reason:
09:38:17 “A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 188.125.73.26:465”
09:38:17 at MailClient.Protocols.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
09:38:17 at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
09:38:17 at MailClient.Commands.Command.Process(WorkerStatus status)
09:38:59 MailClient.Accounts.SocketException: Error when receiving from account [____@Yahoo.co.uk](mailto: ____ @Yahoo.co.uk) : A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 217.146.190.246:995
09:38:59 at MailClient.Protocols.Pop3.Pop3ReceiveCommand.Execute(WorkerStatus status)
09:38:59 at MailClient.Commands.Command.Process(WorkerStatus status)
I have just noticed that when I try to conect without my VPN running I get a different error regarding an ‘unexpected end of stream’ which I haven’t a clue about.
14:57:05 [____@Yahoo.co.uk](mailto: ____ @Yahoo.co.uk) [SMTP] MailClient.Accounts.LoginException: The authentication failed due to the following reason:
14:57:05 "Unexpected end of stream.
