eM Client to taskbar
Hi there!
Mybe it is possible to set up the eM Client,that after boot up the windows, the eM Client moves automatically to the taskbar.
Yes or not, if yes, how?
Thanks in advance your effort!
I don’t believe it is possible via any eMC settings, but this may help
  1. Step 1: Right-click on the shortcut of the program you want to start minimized and select Properties.
  2. Step 2: Click on the drop-down menu under Run.
  3. Step 3: Select “Minimized,” then click the OK button.
Unfortunatly I couldn’t find it,what you describe with the shortcut.
Sorry,sorry,sorry!
It’s prity good solution! BOWING2
Yours might look different depending on Windows version.
