I have formatted my PC. Unfortunately I haven’t exported eM Client settings, but I have the folder copy. Is there any way to recover the settings from that folder?
Just some addition. The folder is from eM Client folder from Program Files
Hello Levon,
the folder in Program files contains no information from your setup, that has been saved in your database folder in C:\Users\your windows user\AppData\Roaming\eM Client.
If that folder has been deleted and if you made no backups, then you cannot recover the settings.
