eM Client repeatedly freezes and becomes unresponsive
When you uninstalled eM Client did you do it via MS Control Panel or did you use a 3rd party software program like Revo Uninstaller etc.?
Revo Uninstaller can remove eM Client and the Registry entries at the one time, it removes it all, making for an absolute clean install.
I used Geek Uninstaller
Ok!
I was curious as to whether you had also cleaned the registry too, so you have an absolutely clean installation.
It’s good to hear that it has been working for you since.
I just did an emClient update and launched without compatibility mode and it froze up. Went back to Compatibility mode and no issue.
Been about 6 weeks and changed back from compatibility mode and it froze again. It has to be something with Windows 11. Works mostly fine in compatibility mode.
I’m having the same issue. Win 10, and I’ve tried to turn on compatibility mode but still it freezes
Just some input, I have been running Win10 Pro and Win10 LTSC for the past many, many years and have never been able to get any of the EM Client V10 versions to work, experiencing constant lockups and entire PC slowdowns. Running v9 I have no issues.
