eM Client printing issues
I’m using eM Client and I love it.
I frequently Print Emails and there is no Print button on the screen displaying the email. I do see if you go to the Hamburger menu, you can select File, and Then Print. You can also just type CTRL-P to open the print dialog box.
My issue with eM Client is that if the print dialog opens to your default printer, and then you select a different printer, eM Client does not read in information about the selected printer.
My default printer is a B/W Samsung laser printer. I also have a commercial Xerox Phaser 6180 MFP that is a color printer.
When I use either method to print, the default printer is my Samsung. If I choose the Xerox Phaser 6180 MFP and then select Print using system dialog, eM Client should display the system dialog for the previously selected printer. I should not have to select the printer a second time!
I tried to attach three images. The forum only allows one!
Hi, could you send me the images in a private message? We’ll take a look.
