Em client on linux
I do think Linux users would buy licenses, just not enough of them to generate significant income to make a port worth it based on the total amount of users that use Linux as a desktop OS when compared to the user base for Windows and MacOS X. They have made it clear a port is not easy, but if someday it was or the amount of desktop users that use Linux increase dramatically, then it might make more sense. Of course people are voting on this feature so who knows maybe enough votes will convince them. Short term the only solution I can see that doesn’t involve having to install Windows OS itself, is using a software that translates Windows API calls, such as WINE. When you do this you are not using virtualization or emulating the software, you are installing eM Client into a Linux type container that just translates the Windows API calls to Linux API calls.
I would like to see a Linux version myself, but I also understand if the eM Client staff at this time point out a port is not easy and it doesn’t make financial sense based on the amount of Linux Desktop users.
For the record, I tried it with Proton and GE Proton, made no difference to the notifications being blank unfortunately. Was worth a shot I guess.
I decided to no longer use Bottles, personally. I created an executable script specifying the runner and prefix and pointed a start menu entry at it to make it behave like an actual app without running Bottles in the background. Works just the same in practice but I think Bottles is more friendly to new Linux users.
I would never rely on an emulated version of emclient.
For clarification, this is not an emulated version of eM Client, it’s just the one and only authentic eM Client. Only difference being it’s running inside an environment it wasn’t developed for. The compatibility layer is doing all the work to rectify this.
Porting the software means answering the Wayland X11 issue, I think that needs more time to mature.
@BigR What’s a Wayland X11 issue?
The question is what to prefer, Wayland or X11. I ran into difficulties with Wayland and proprietary software.
To fix the issue of the maximised window title bar getting all messed up and hiding the search feature edit the configuration of the bottle (i think under display settings) and turn off the setting to have your environment decorate the window.
I also changed the bottle to emulate windows 8. I think that also solved the notification text fade issue.
Changing from windows 10/11 emulation also solves the problem of the setting dialogs not starting properly. Windows 8 or 7 (either one) solved that for me.
The last issue i have running em client on wine via bottles (crossover to be specific) is that you can’t enter a license code… it takes it, thinks about processing it and displays a spinner… but never actually saves the license or applies it.
Also second order menus like View => Layout don’t draw properly… but that’s very minor.
Other than that, so long as you have all the windows fonts installed into the bottle it works really well.
@grover
I fixed this in KDE by disallowing decorations for eM Client from the System settings. But I wasn’t sure this was possible across the board
You are right. I found a good runner that makes eM Client correctly display the text within notifications and allows for license activation, it’s UMU-Proton-9.0-4.
I’ve done a bunch of regedits to get eM Client working smoothly with Bottles. It supports various fonts and double-clicking on attachments opens them natively on Linux. I’ve started documenting how I achieved it at GitHub - BenJamesAndo/Linux-eMClient: Instructions on getting eM Client running on Linux using WINE
I’ve also been playing around with bundling it all up into an AppImage which would make it super easy for anyone on Linux to run.
Just found this mail client: https://aerion.3df.io/
Seems to be very new. And this is exactly the gap they are trying to fill: A good email client for Linux that is modern etc. Exactly, what eM should do and hopefully will do sometime :slight_smile:
Switched to Linux now, and… unfortunately… switched to another Mail client now.
Michael
I tried that one but on my end it causes eM Client to crash when right clicking. Is there a fix for this?
I did find it crashed on Windows 10 or 11 a bit but if you try Windows 8.1 it should be stable.
Wine-GE-Proton8-26 also shows notification text correctly.
It would be great to see full native Linux support soon for Em Client!
With the path Microsoft has choosen it drives customers to other alternatives. Mostly to Linux.
Compagnues who only have Windows versions, will also lose there customers because they don’t support other OS.
So staying with Windows will drag those compagnies down. Adobe is such a company, The already lost millions of income because of that.
There are plenty of alternatives for windows now.
miƩrcoles 18 marzo 2026 :: 1542hrs (UTC +0100)
EM Client on Linux?
Very, very difficult to present a ROI argument.
Interestingly we have recently completed a market share analysis for a
multi-national client that was presented yesterday.
Here is a small snapshot focused on Linux, Windows & MacOS.
Linux desktop market share has grown significantly, exceeding 4% globally in 2025
to reach over 5% in the US.
Over the same period Windows still dominates desktops at around 68% to 71%M
MacOS maintains about 16% to 20%
Linux dominates servers at about 44%+
Linux has 100% of the top 500 supercomputing
Ubuntu is the top distro and has rising popularity wih devops
We have not included the bulk of the report, however, it is possible that the
growth of Linux was in part because of Windows 10 support issues, and might
slow as it is now straightforward and possible to move to Windows 11 with a
bypass of TPM 2.0 and Secure Boot giving full functionality from a local
ISO file install download direct from Microsoft.
ADDENDUM
For anyone who is interested as a test I asked two of our interns
who have no particular computer knowledge, to updated six randomly
selected (4 laptops & 2 desktops) all running Win10 Pro that did
not meet the TPM 2.0 and Secure Boot requirements.
All worked perfectly and is FREE of charge, you have the option
to keep existing settings and Apps.
You do NOT need anything other than a basic understanding of
computer use,
We can provide FREE by email FULL simple instructions if asked.
Use the email address below.
skybat
”Buena suerte!
”Saludos desde Sevilla la soleada en España!
”Mis mejores deseos y mantente a salvo!
Hablo espaƱol, luego portuguƩs, inglƩs, francƩs y alemƔn
Throwing my hat into the Linux ring too. My company fully uses Linux (specifically NixOS) and I myself am migrating out of the Windows 11 ecosystem. I have been a Windows user all my life, but the recent AI slop and privacy issues of Windows have pushed me away. Worse still: Windows shows me ads directly in the OS itself that angers me. Countries are taking notice too and entire governments in Europe are moving to Linux too. It’s only a matter of time.
I saw Wayland or X11 being brought up. I think if any effort is made to make a Linux version, it should jump right on Wayland right away, since the major desktop environments GNOME and KDE both default to Wayland now.
+1 For a Linux client. The main reason I haven’t gone full Linux is EM Client and I’m getting to the point where I’ll need to find an alternative.
I really feel EM Client would get a significant portion of the Linux market as this area is woefully undeserved.
At this point your best option to get eM Client running on Linux is to use WINE. A forum user created these instructions to help with the process:
If it makes things easier to port to linux: Just leave out the MineSweeper game. Maybe that gives more ressources for porting… :stuck_out_tongue:
At this point we so many users show interest for a native Linux version. Just make one and see how the market reacts!
I also would like to see a Linux version. But for the time being, it seems to run fine with WinBoat. Of course, not an option for everyone.
