eM Client on a HI-DIP monitor
I’ve moved to a 28" 4K monitor. Great pictures but the text (actually everything) in eM Client is too small to read.
Anyone figure out a workaround for this?
Support says they have some “adjustments” coming in the next update but that’s still 6-8 weeks away and may not be the answer.
Hello Courtney,
you can zoom in the text of emails using the mouse scroll and Ctrl button.
For the lists, you can change some of the Layout font sizes in Tools > Settings > Appearance > Lists.
I’m afraid the rest of version 6 isn’t adjustable in size.
If this is making eM Client unusable for you for now I can suggest lowering your DPI settings, though I know that is not the best work around.
Best regards,
The mouse scroll is a great tip and takes care of the biggest problem right now.
Thanks for that!
