eM Client is SUPERB !!
I am using eM Client for a while. It is awesome !! I would recommend it to anyone who is looking for a good email client.
thank you very much for your support.
with regards,
Jan
I agree. After - really, seriously - 20 years of using Eudora (I still think it’s the best email application ever devised, and will argue anyone into the ground on its behalf), I looked to replace it. I tried pretty much everything out there and eM Client has the most in its favor. It’s a beautifully thought-out application, and I appreciate the support very much.
This doesn’t mean it’s perfect, and I have lots of problems with it that I hope will improve over the years. But one wants to use an important business tool for a very long time, and so I shall be patient, and hope that you’ll continue to listen to users and make the application even better. Best of luck with that. For now, eM Client has a superb feature set and does nearly everything I need it to. Thanks.
thank you for your support :slight_smile:
Jan
