eM Client Initial Syncing
I have a rather large GMail mailbox with over 25GB of stored email (since 2005) and at the initial sync process, eM client stops syncing around August 2010. When you make the next update can you add a profile to sync “back” to a certain date from gmail to reduce my local PC-client foot print and sync process?
Thanks
AG
are you downloading your messages for Offline use? It would explain this syncing issue, because the intended behaviour is to not download message until it is selected (click on it or open in new window).
