eM Client hangs after waking up from stand by.
This does not happen each time but has happened many times. The problem is: when my computer wakes up, sometimes eM is not able to get new mails. When I check the operations status, it shows that the IMAP connection to my gmail server is hanging there, with an empty progress bar. If I wait, it will stay like that forever. The only cure is to restart the program. It works but is annoying.
Anyway to fix this problem? I guess even a simple timer to restart the TCP connections in the program would avoid such problems.
in order to resolve this problem I would like to ask you for cooperation:
- Download this application: http://www.emclient.com/tools/emstack… and run it after your computer wakes up. It will generate a log file (starting with “eM Client Stack” in your Documents folder) that will help us analyze the problem in more detail. Please attach this file to your reply.
- Go to: Tools - Settings - Logging, check “Network Communication” and restart eM Client. Try to simulate the issue and send us the log using the logging settings window. Thank you.
Hello I have this problem too. I’ve just sent you an email.
