Hi, GMX has required TLS 1.2 or 1.3 since June 1st, 2022 – The old security protocols TLS 1.0 and 1.1 are dead. This makes SMTP impossible and eM Client useless. When will there be an update? Cheers
eM Client uses TLS 1.2 without any issue.
But users of Windows 7 will have an issue as TLS 1.2 is disabled by default in their OS.
If that is what you have, you can enable it in your Windows Registry. See: https://manage.accuwebhosting.com/knowledgebase/3008/How-do-I-enable-TLS-1-2-on-Windows-7.html
Thank you Gary for the quick support and this registry hack. It works
