I am having a very consistent problem of mailclient.exe no closing when exiting eM Client. About 80% of the time the program closes, but mailclient.exe is still open in Windows Task Manager. I am sending stack file to [email protected]
I think I am having the similar problem which just happened and I can’t even get into my eM Cleint email program now. IF this cant be fix what use is the program?
System.Data.SQLite.SQLiteException: Some kind of disk I/O error occurred
disk I/O error (main/5)
at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt)
at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at DbRepair.DbTools.OpenConnection(String fileName)
at DbRepair.Form1.CheckCorruption()
at DbRepair.Form1.Check(Object state)
please do not post same issue twice into different topics, also beta thread is this https://discourse.emclient.com/emclient/to… so all beta issues please put there, otherwise forum gets unclear.
Unfortunately we cant make thread different than how they are now, but that one beta thread will be still same until release of full version.
Unfortunately I am having quite a lot work outside forum too so I was unable to attend it as it is needed, I hope that until end of this week I will response and report issues from beta forum to devs at all.
I forced close of eMail client and it is now refusing to launch, ven after DB check which it says has failed. Is there a fix other than uninstall and re-install?
