I followed instructions carefully and got all my required information for my email: the host, the IMAP security protocol and port; the same for SMTP, including my provider’s suggested TLS instead of eM’s STARTTLS default option. It pops up a request for my password, which I have also confirmed and then fails telling me my credentials were rejected. I did all pwsh tests and there is nothing wrong with my credentials or certificate. I can send and receive emails from my domain box to gmail without a problem. Can I get some help on this?
Hi @silvanet,
Could you please let us know which email provider/hosting company hosts your domain and mailbox? If possible, please also provide the domain name (you may redact the specific mailbox address if you prefer).
We would like to check the provider’s requirements, as some email providers require an app-specific password or a different authentication method for third-party email applications such as eM Client, particularly when two-factor authentication is enabled. eM Client supports such setups, but the requirements depend on the mail provider.
Please also let us know:
- The exact IMAP server and port you are using
- The exact SMTP server and port
- Whether your provider specifically instructed you to use TLS rather than STARTTLS
- Whether two-factor authentication (2FA) is enabled on the mailbox
- The exact error message displayed by eM Client when the credentials are rejected
Once we know which provider hosts the mailbox, we can check whether an app password or another authentication method is required and advise you on the correct eM Client configuration.
