em client does not follows rules
I created a rule “After message has been received with ‘Indeed’ found in subject move to Indeed”
Indeed is a sub-folder a couple of levels under the inbox.  But when I run the rule, it says it completes, but nothing happens.  The emails do not get moved.  I did a search with indeed as the key word and there were plenty of emails that came up.
I created another rule for emails received from ‘indeed.com’ move to Indeed.  That also did not work.  I can’t be any clearer.  Why are these rules failing?  Please help.  I am on en employment search.  I get dozens of emails daily from a dozen different job search boards.  I need them to filter into the proper folder.
Please help!
Can you please send me a screenshot of the contects of the rule? Thank you.
Dave
