eM Client crashesh after installing of Kaspersky
eM Client crashesh after installing of Kaspersky. eM Client is updated to the last version 6.022344.0
Hello Sabin, if the application crashes is the error report window displayed after the crash occurs? If so, please click on the “Show error” button and submit the error to us here for more information about this issue.
Thank you.
This is the error
eM Client (6.0.22344.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.18408
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.ArgumentException: Parameter is not valid.
   at System.Drawing.Image.get_RawFormat()
   at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y, Int32 width, Int32 height)
   at System.Drawing.Graphics.DrawImage(Image image, Rectangle rect)
   at MailClient.UI.Forms.BalloonForms.FormBalloonDetail.updateBackgroundBitmap()
   at MailClient.UI.Forms.LayeredBaseForm.updateLayeredBackground(Boolean refreshBitmap)
   at MailClient.UI.Forms.BalloonForms.FormBalloonDetail.OnResize(EventArgs e)
   at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
   at MailClient.UI.Forms.ThemeForm.OnSizeChanged(EventArgs e)
   at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
   at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height)
   at System.Windows.Forms.Control.SetBoundsCore(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
   at System.Windows.Forms.Form.SetBoundsCore(Int32 x, Int32 y, Int32 width, Int32 height, BoundsSpecified specified)
   at System.Windows.Forms.Control.ScaleControl(SizeF factor, BoundsSpecified specified)
   at System.Windows.Forms.ScrollableControl.ScaleControl(SizeF factor, BoundsSpecified specified)
   at System.Windows.Forms.Form.ScaleControl(SizeF factor, BoundsSpecified specified)
   at System.Windows.Forms.Control.ScaleControl(SizeF includedFactor, SizeF excludedFactor, Control requestingControl)
   at System.Windows.Forms.ContainerControl.Scale(SizeF includedFactor, SizeF excludedFactor, Control requestingControl)
   at System.Windows.Forms.ContainerControl.PerformAutoScale(Boolean includedBounds, Boolean excludedBounds)
   at System.Windows.Forms.ContainerControl.PerformNeededAutoScaleOnLayout()
   at System.Windows.Forms.ContainerControl.OnLayoutResuming(Boolean performLayout)
   at System.Windows.Forms.Control.ResumeLayout(Boolean performLayout)
   at MailClient.UI.Forms.FormPopup.InitializeComponent()
   at MailClient.UI.Forms.FormPopup…ctor()
   at MailClient.UI.Forms.BalloonForms.FormBalloonDetail…ctor()
   at MailClient.UI.Forms.BalloonForms.FormBalloonAttachmentDetail…ctor()
   — End of inner exception stack trace —
   at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
   at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
   at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark)
   at System.Activator.CreateInstance(Type type, Boolean nonPublic)
   at System.Activator.CreateInstance(Type type)
   at MailClient.UI.BalloonDetail.BalloonManager.prepareBalloonForm(Type formType)
   at MailClient.UI.BalloonDetail.BalloonManager.ShowBalloon(Type formType, Object value, Rectangle rect, BalloonAlignment alignment, Object additionalInfo)
   at MailClient.UI.Controls.ControlHeaderAttachments.checkMousePositionToShowBalloon(Point mouseLocation)
   at MailClient.UI.Controls.ControlHeaderAttachments.OnMouseMove(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseMove(Message& m)
   at System.Windows.Forms.UserControl.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
   at MailClient.Program.b__4()
at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action1 handler)<br><br><br><report xmlns="&lt;a href=" http:>" rel="nofollow" target="_blank"&gt;http://emclient.com/ns/report"&gt;;<br> <product><br> <name>eM Client</name><br> <version>6.0.22344.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 6.1.7601 Service Pack 1</osversion><br> <frameworkversion>4.0.30319.18408</frameworkversion><br> </environment><br> <exception><br> <type>System.Reflection.TargetInvocationException</type><br> <message>Exception has been thrown by the target of an invocation.</message><br> <source>mscorlib</source><br> <stack><br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100667774</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.RuntimeTypeHandle</type><br> <name>CreateInstance</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.RuntimeType</type><br> <name>type</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>publicOnly</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>noCheck</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean&amp;</type><br> <name>canBeCached</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.RuntimeMethodHandleInternal&amp;</type><br> <name>ctor</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean&amp;</type><br> <name>bNeedSecurityCheck</name><br> </parameter><br> </parameters><br> </method><br> <offset>ffffffff</offset><br> <nativeoffset>0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100667627</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.RuntimeType</type><br> <name>CreateInstanceSlow</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>publicOnly</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>skipCheckThis</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fillCache</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.StackCrawlMark&amp;</type><br> <name>stackMark</name><br> </parameter><br> </parameters><br> </method><br> <offset>6f</offset><br> <nativeoffset>71</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100667628</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.RuntimeType</type><br> <name>CreateInstanceDefaultCtor</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>publicOnly</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>skipCheckThis</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>fillCache</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Threading.StackCrawlMark&amp;</type><br> <name>stackMark</name><br> </parameter><br> </parameters><br> </method><br> <offset>aa</offset><br> <nativeoffset>e8</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100664654</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Activator</type><br> <name>CreateInstance</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Type</type><br> <name>type</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>nonPublic</name><br> </parameter><br> </parameters><br> </method><br> <offset>3a</offset><br> <nativeoffset>53</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100664651</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.Activator</type><br> <name>CreateInstance</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Type</type><br> <name>type</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>6</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100677775</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.BalloonDetail.BalloonManager</type><br> <name>prepareBalloonForm</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Type</type><br> <name>formType</name><br> </parameter><br> </parameters><br> </method><br> <offset>31</offset><br> <nativeoffset>4a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100677769</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.BalloonDetail.BalloonManager</type><br> <name>ShowBalloon</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Type</type><br> <name>formType</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>value</name><br> </parameter><br> <parameter><br> <assembly>System.Drawing</assembly><br> <type>System.Drawing.Rectangle</type><br> <name>rect</name><br> </parameter><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.BalloonDetail.BalloonAlignment</type><br> <name>alignment</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>additionalInfo</name><br> </parameter><br> </parameters><br> </method><br> <offset>a1</offset><br> <nativeoffset>158</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100678346</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.ControlHeaderAttachments</type><br> <name>checkMousePositionToShowBalloon</name><br> <parameters><br> <parameter><br> <assembly>System.Drawing</assembly><br> <type>System.Drawing.Point</type><br> <name>mouseLocation</name><br> </parameter><br> </parameters><br> </method><br> <offset>b9</offset><br> <nativeoffset>24a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100678338</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.ControlHeaderAttachments</type><br> <name>OnMouseMove</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.MouseEventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>7c</offset><br> <nativeoffset>16a</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665752</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>WmMouseMove</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&amp;</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>37</offset><br> <nativeoffset>68</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665461</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&amp;</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>571</offset><br> <nativeoffset>45b</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665975</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ScrollableControl</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&amp;</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>3a</offset><br> <nativeoffset>29</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100682734</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.UserControl</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&amp;</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>13</offset><br> <nativeoffset>22</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665839</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control+ControlNativeWindow</type><br> <name>OnMessage</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&amp;</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>10</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665840</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control+ControlNativeWindow</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&amp;</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>8e</offset><br> <nativeoffset>34</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100665822</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.NativeWindow</type><br> <name>DebuggableCallback</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>hWnd</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>wparam</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>lparam</name><br> </parameter><br> </parameters><br> </method><br> <offset>25</offset><br> <nativeoffset>5d</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100663535</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.UnsafeNativeMethods</type><br> <name>DispatchMessageW</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.NativeMethods+MSG&amp;</type><br> <name>msg</name><br> </parameter><br> </parameters><br> </method><br> <offset>ffffffff</offset><br> <nativeoffset>0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100688501</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ComponentManager</type><br> <name>System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>dwComponentID</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>pvLoopData</name><br> </parameter><br> </parameters><br> </method><br> <offset>186</offset><br> <nativeoffset>24c</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100688548</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ThreadContext</type><br> <name>RunMessageLoopInner</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>1de</offset><br> <nativeoffset>154</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100688547</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ThreadContext</type><br> <name>RunMessageLoop</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>13</offset><br> <nativeoffset>49</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100664859</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application</type><br> <name>Run</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>17</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100675710</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Program</type><br> <name>&lt;Main&gt;b__4</name><br> <parameters></parameters><br> </method><br> <offset>17</offset><br> <nativeoffset>42</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.ExceptionUtils.dll</modulename><br> <metadatatoken>100663314</metadatatoken><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils</type><br> <name>Filter</name><br> <parameters><br> <parameter><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils+BodyDelegate</type><br> <name>body</name><br> </parameter><br> <parameter><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils+FilterDelegate</type><br> <name>filter</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Action1[[System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]
handler
0
22
System.Drawing
System.Drawing.dll
100663369
System.Drawing
get_RawFormat
0
1160c1
System.Drawing.dll
100663994
System.Drawing
DrawImage
System.Drawing
mscorlib
System.Int32
x
mscorlib
System.Int32
y
mscorlib
System.Int32
width
mscorlib
System.Int32
height
32
58
System.Drawing.dll
100663993
System.Drawing
DrawImage
System.Drawing
System.Drawing
rect
0
13
MailClient.exe
100674309
MailClient
131
28b
MailClient.exe
100671843
MailClient
mscorlib
System.Boolean
refreshBitmap
44
6c
MailClient.exe
100674312
MailClient
OnResize
mscorlib
System.EventArgs
e
0
19
100665375
OnSizeChanged
mscorlib
System.EventArgs
e
0
26
MailClient.exe
100667258
MailClient
OnSizeChanged
mscorlib
System.EventArgs
e
0
e
100665454
UpdateBounds
mscorlib
System.Int32
x
mscorlib
System.Int32
y
mscorlib
System.Int32
width
mscorlib
System.Int32
height
mscorlib
System.Int32
clientWidth
mscorlib
System.Int32
clientHeight
85
a2
100665453
&nbs
Can you please describe the applications behavior more closely, does the application crash on startup or when trying to perform a specific action?
Thank you.
On startup doesn’t crash, It crashes for example If I write e-mail or if I minimize and open it sever time
Hello again, so if you submit the message, when you hit send the error occurs? Can you please try to install this update and check if the issue persists?
6.0.22465.0
Thank you.
