Having the same issue here. I cannot delete the Exchange account, nor can I disable it. If I ignore the error dialog, it then shows me “Deleting Account - This operation may take a while to complete”. It hasn’t completed yet, so I don’t know if it actually will ever finish.
Hi, when this error occurs, can you please switch to the Log tab in the operations window and copy the content of the Log and post it either here or to my email?
Hi, can you please try to download this latest release of eM client, it should contain a lot of bug fixes regarding the Exchange issue, http://www.emclient.com/dist/v6.0.21005/setup.msi .
Please install the update and let me know if issues persist.
In trying this update, I still get the same error as mentioned above. I’ve also tried deleting the OAB file from the eM Client directory. The good news is that I now again seem to be able to make changes to the Exchange calendar in eM Client and have those changes reflected on the server.
Thank you so much for all your help.
Hi again David,
if you switch to the Log tab when the error occurs, can you see the same error as in the previous version? If you’re not sure, just send me the content of the Log again.
Paul,
I think the relevant error log section is below. Feel free to ask if you need anything else. Thank you so much for all your efforts.
4:52:17 PM Exchange [Offline Address Book] MailExceptions.ConnectionException: Index was outside the bounds of the array. —> System.IndexOutOfRangeException: Index was outside the bounds of the array.4:52:17 PM at Microsoft.Xna.Framework.LzxDecoder.Decompress(Stream inData, Int32 inLen, Stream outData, Int32 outLen)
4:52:17 PM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.UncompressLzx(Stream fullFile, Stream outputFile)
4:52:17 PM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.GetFolderList(Folder homeFolder, CancellationToken cancellationToken)
4:52:17 PM at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass5.b__0(WorkerStatus status, CancellationToken cancellationToken)
4:52:17 PM at MailClient.Protocols.OfflineAddressBook.OabGenericCommand.Execute(WorkerStatus status)
4:52:17 PM — End of inner exception stack trace —
4:52:17 PM at MailClient.Commands.Command.Process(WorkerStatus status)
Hi again David, please update your application to this most recent release http://www.emclient.com/dist/v6.0.21015/setup.msi , this update contains more bug fixes and you should no longer see the error.
Paul,
Thanks so much for this update. I’ve installed the eM Client version you’ve mentioned here (6.0.21015), but I’m still seeing the error with the Exchange Offline Address book as described above. What looks to be the relevant excerpt from the log is below.
Thank you, again, for all your help.
4:57:05 PM Exchange [Offline Address Book] Synchronizing folder list4:57:05 PM Exchange [Exchange Web Services] Synchronizing folder list
4:57:06 PM Exchange [Offline Address Book] MailExceptions.ConnectionException: Index was outside the bounds of the array. —> System.IndexOutOfRangeException: Index was outside the bounds of the array.
4:57:06 PM at Microsoft.Xna.Framework.LzxDecoder.Decompress(Stream inData, Int32 inLen, Stream outData, Int32 outLen)
4:57:06 PM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.UncompressLzx(Stream fullFile, Stream outputFile)
4:57:06 PM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.GetFolderList(Folder homeFolder, CancellationToken cancellationToken)
4:57:06 PM at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass5.b__0(WorkerStatus status, CancellationToken cancellationToken)
4:57:06 PM at MailClient.Protocols.OfflineAddressBook.OabGenericCommand.Execute(WorkerStatus status)
4:57:06 PM — End of inner exception stack trace —
4:57:06 PM at MailClient.Commands.Command.Process(WorkerStatus status)
Hi David, thank you for reporting this, I was notified from one of our developers that a fix for the issue should be included in an upcoming update, please be patient the update should be released soon.
I’ll let you know when the update is available for download or when I get more information about the issue.
Hi again David, can you please download this update : http://www.emclient.com/dist/v6.0.21032/setup.msi , install the update on your computer, once again, please remove all the existing *.oab files in your eM Client database folder in your local folder > App Data > Roaming > eM Client, and check if the issue persists…
The update contains more fixes regarding exchange accounts and should hopefully be resolved completely.
But if the issue persists, please let me know.
Thanks, Paul. Unfortunately, this new update, seems to reinstitute the crash-restart-repeat cycle again. In addition to what you’ve suggested, I’ve full uninstalled eM Client, deleted the eM Client folder under Roaming, and reinstalled. On importing settings, the Exchange account is disabled like I described earlier. On deleting the account and recreating it, the crash, restart, repeat cycle begins anew. Deleting the OAB file seemingly makes no difference.
The full text of the error report is below for reference.
eM Client (6.0.21032.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.18444
System.NotSupportedException: This stream does not support seek operations.
at System.Net.ConnectStream.get_Position()
at MailClient.Commands.SynchronizationQueue.ThreadWorker(Object threadData)
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ThreadHelper.ThreadStart(Object obj)
" rel=“nofollow” target="_blank">http://emclient.com/ns/report">;
eM Client
6.0.21032.0
false
4.0.30319.18444
System.dll
100673629
System
get_Position
f
39
MailClient.exe
100668770
MailClient
UncompressLzx
mscorlib
System.IO.Stream
fullFile
mscorlib
System.IO.Stream
outputFile
a0
162
MailClient.exe
100668771
MailClient
GetFolderList
MailClient
MailClient.Storage.Application.Folder
homeFolder
MailClient
System.Threading.CancellationToken
cancellationToken
51f
ae0
MailClient.exe
100697499
MailClient
MailClient.Protocols.Common.FolderSynchronizer+<>c DisplayClass5
<EnqueueGetFolderList>b 0
MailClient
MailClient.Commands.WorkerStatus
status
MailClient
cancellationToken
1e
6f
MailClient.exe
100668764
MailClient
Execute
MailClient
status
4f
10d
MailClient.exe
100664007
MailClient
Process
MailClient
status
15
53
MailClient.exe
100664057
MailClient
ThreadWorker
mscorlib
System.Object
threadData
8c
11c
mscorlib.dll
100669199
mscorlib
ThreadStart_Context
mscorlib
System.Object
state
25
9b
mscorlib.dll
100668967
mscorlib
RunInternal
mscorlib
executionContext
mscorlib
System.Threading.ContextCallback
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
70
a6
mscorlib.dll
100668966
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
0
15
mscorlib.dll
100668965
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
2b
40
mscorlib.dll
100669196
mscorlib
ThreadStart
mscorlib
System.Object
obj
f
4d
MailClient.exe
C:\Program Files\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
6.0.21032.0
eM Client
eM Client
6.0.21032.0
False
False
False
False
False
Language Neutral
ntdll.dll
C:\Windows\SYSTEM32\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.1.7600.16385 (win7_rtm.090713-1255)
NT Layer DLL
Microsoft® Windows® Operating System
6.1.7600.16385
False
False
False
False
False
English (United States)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
4.0.40305.0 (Main.040305-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.40305.0
False
False
False
True
False
KERNEL32.dll
C:\Windows\system32\KERNEL32.dll
kernel32
kernel32
6.1.7601.18015 (win7sp1_gdr.121129-1432)
Windows NT BASE API Client DLL
6.1.7601.18015
False
False
False
False
False
KERNELBASE.dll
C:\Windows\system32\KERNELBASE.dll
Kernelbase
Kernelbase
6.1.7601.18015
False
False
False
False
False
ADVAPI32.dll
C:\Windows\system32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
Advanced Windows 32 Base API
6.1.7600.16385
False
False
False
False
False
msvcrt.dll
C:\Windows\system32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.7601.17744 (win7sp1_gdr.111215-1535)
Windows NT CRT DLL
7.0.7601.17744
False
False
False
False
False
sechost.dll
C:\Windows\SYSTEM32\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.1.7600.16385
False
False
False
False
False
RPCRT4.dll
C:\Windows\system32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
6.1.7600.16385
False
False
False
False
False
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.0.30319.18408 built by: FX451RTMGREL
4.0.30319.18408
False
False
False
True
False
SHLWAPI.dll
C:\Windows\system32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell Light-weight Utility Library
6.1.7600.16385
False
False
False
False
False
GDI32.dll
C:\Windows\system32\GDI32.dll
gdi32
gdi32
6.1.7601.18577 (win7sp1_gdr.140822-1508)
GDI Client DLL
6.1.7601.18577
False
False
False
False
False
USER32.dll
C:\Windows\system32\USER32.dll
user32
user32
6.1.7601.17514 (win7sp1_rtm.101119-1850)
Multi-User Windows USER API Client DLL
6.1.7601.17514
False
False
False
False
False
LPK.dll
C:\Windows\system32\LPK.dll
LanguagePack
LanguagePack
6.1.7601.18177 (win7sp1_gdr.130605-1534)
Language Pack
6.1.7601.18177
False
False
False
False
False
USP10.dll
C:\Windows\system32\USP10.dll
Uniscribe
Uniscribe
1.0626.7601.18454 (win7sp1_gdr.140424-1533)
Uniscribe Unicode script processor
Microsoft® Uniscribe Unicode script processor
1.0626.7601.18454
False
False
False
False
False
IMM32.DLL
C:\Windows\system32\IMM32.DLL
imm32
imm32
Multi-User Windows IMM32 API Client DLL
6.1.7601.17514
False
False
False
False
False
MSCTF.dll
C:\Windows\system32\MSCTF.dll
MSCTF
MSCTF.DLL.MUI
MSCTF Server DLL
6.1.7600.16385
False
False
False
False
False
clr.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll
clr.dll
clr.dll
4.0.30319.18444 built by: FX451RTMGDR
Microsoft .NET Runtime Common Language Runtime - WorkStation
4.0.30319.18444
False
False
False
True
False
MSVCR110_CLR0400.dll
C:\Windows\system32\MSVCR110_CLR0400.dll
msvcr110_clr0400.dll
11.00.50938.18408 built by: FX451RTMGREL
Microsoft® C Runtime Library
Microsoft® Visual Studio® 11 Beta
11.00.50938.18408
False
False
False
False
False
mscorlib.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\ce5f61c5754789df97be8dc991c47d07\mscorlib.ni.dll
mscorlib.dll
mscorlib.dll
Microsoft Common Language Runtime Class Library
4.0.30319.18444
False
False
False
True
False
ole32.dll
C:\Windows\system32\ole32.dll
OLE32.DLL
OLE32.DLL.MUI
Microsoft OLE for Windows
6.1.7600.16385
False
False
False
False
False
CRYPTBASE.dll
C:\Windows\system32\CRYPTBASE.dll
cryptbase.dll
cryptbase.dll
Base cryptographic API DLL
6.1.7600.16385
False
False
False
False
False
uxtheme.dll
C:\Windows\system32\uxtheme.dll
UxTheme.dll
UxTheme.dll.mui
Microsoft UxTheme Library
6.1.7600.16385
False
False
False
False
False
System.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System\9b943fcb3af2101cfb3467161c6ac0ed\System.ni.dll
System.dll
System.dll
.NET Framework
4.0.30319.18408
False
False
False
True
False
CRYPTSP.dll
C:\Windows\system32\CRYPTSP.dll
cryptsp.dll
cryptsp.dll
Cryptographic Service Provider API
6.1.7600.16385
False
False
False
False
False
rsaenh.dll
C:\Windows\system32\rsaenh.dll
rsaenh.dll
rsaenh.dll
Microsoft Enhanced Cryptographic Provider
6.1.7600.16385
False
False
False
False
False
MailClient.Collections.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.1d52ed9e#\45bbfe32dbef475e6dd5ccf5a33bc4ac\MailClient.Collections.ni.dll
MailClient.Collections.dll
6.0.21032.0
6.0.21032.0
False
False
False
False
False
Language Neutral
MailClient.Mail.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Mail\c8f23cf81080450ed5eb647cacde0554\MailClient.Mail.ni.dll
MailClient.Mail.dll
MailClient.Mail.dll
6.0.21032.0
6.0.21032.0
False
False
False
False
False
Language Neutral
HTMLEditorControl.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\HTMLEditorControl\9166adff116656aef9fde895dcc3fbfc\HTMLEditorControl.ni.dll
HTMLEditorControl.dll
6.0.21032.0
HtmlEditorControl
6.0.21032.0
False
False
False
False
False
Language Neutral
MailClient.ni.exe
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient\3c40cfac2d12cac943d49000882e4dc7\MailClient.ni.exe
MailClient.exe
MailClient.exe
6.0.21032.0
eM Client
eM Client
6.0.21032.0
False
False
False
False
False
Language Neutral
System.Drawing.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\5cd2aee5e7c07227c694d89219688ab3\System.Drawing.ni.dll
System.Drawing.dll
System.Drawing.dll
.NET Framework
4.0.30319.18408
False
False
False
True
False
System.Windows.Forms.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\b51470d7e909c4fab01a25fd1e1c42dc\System.Windows.Forms.ni.dll
System.Windows.Forms.dll
.NET Framework
4.0.30319.18408
False
False
False
True
False
MailClient.Common.UI.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Common.UI\88f79b8cd599ee6bc0de71aafa0350a3\MailClient.Common.UI.ni.dll
MailClient.Common.UI.dll
6.0.21032.0
6.0.21032.0
False
False
False
False
False
Language Neutral
MailClient.Interop.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.Interop\639148d286135afed4a3266aef7ca188\MailClient.Interop.ni.dll
MailClient.Interop.dll
6.0.21032.0
6.0.21032.0
False
False
False
False
False
Language Neutral
MailClient.ExceptionUtils.ni.dll
C:\Windows\assembly\NativeImages_v4.0.30319_32\MailClient.ad6c0f7b#\e7b47a5a7c52bdbded61717df2153488\MailClient.ExceptionUtils.ni.dll
MailClient.ExceptionUtils.dll
1.0.0.0
Hi again David, I’m sorry for this inconvenience, seems like the release of this update was a bit premature, can you please downgrade to the previous version (http://www.emclient.com/dist/v6.0.21015/setup.msi), while we work on the fix for the issue, in order to downgrade to a previous release, you have to uninstall the application and install the older version after uninstalling.
I’m forwarding this info to the developers for more information.
Thanks, Paul. The downgrade set things to working again as before. The update to 6.0.21034 just came through too, and that seems to have resolved the remaining error message for the Exchange offline address book.
Hi again David, glad you were able to update to the 6.0.21034 version as this should be the final update to this issue. I’m sorry for the inconvenience caused by this issue, and thank you for your time spent on resolving the issue, please let me know if you come across any other issues or questions with the application, I’ll be happy to help.
For other users following this issue, please update your client to this version http://www.emclient.com/dist/v6.0.21034/setup.msi , let me know if any issues occur.
Thanks to the efforts of the eM Client team, and the updates we’ve received over the last few days, I no longer have errors. However, this has led to the exposure of a different issue. Now that eM Client is successfully synchronising my corporate offline addressbook, it’s noticeable that it’s consuming quite an amount of resource doing so. I can understand why - my OAB contains 22975 entries. So every 10 minutes (which I would not call a particularly adventurous figure), eM Client spends up to 2 minutes hammering away at the CPU and the disk, reading them all and writing them to disk. So I have a question - is it possible to set the OAB to somehow synchronise at a different frequency from normal mail folders, or not at all?
If it would be preferable for me to post this as a separate thread, I’ll be happy to do so, or mods can move it if necessary.
Thanks
Nick
Hi Nick, can you please go to Tools > Settings > Advanced, and turn on Exchange Web Services and Offline Address Book logging for the problematic account.
- Save the settings
- Restart the application
- Replicate the issue
Once the issue reoccurs, please go back to the advanced settings window and click on “Send logs” and send the logs to my email [email protected] with a reference link to this forum topic.
Logs sent. Thanks Paul.
Hi again, thank you for the received data, I have submitted your logs to the developers for more information about the issue.
