I have two questions:
1. What is the difference between Contacts and its subfolder MyContacts?
2. When I MOVE a contact from subfolder A to subfolder B, this contact still remains in subfolder A. Why?
Thank you
Thank you
Maybe a Google user can confirm, but I believe that My Contacts is a Google Contact label. In eM Client, it will also be displayed as a category.
Try right-click on the contact and select Categorize, then remove the sub-folder A category. My guess is that the contact is being copied and not moved, so it has both labels.
