eM Client changed to Dark Background
I was trying to widen the width of the scrollbar when the background turned DARK. How do I get it back?
Seems like several versions ago there was a whole library of themes.
To restore your Theme if it’s gone wrong, If you had a custom Theme saved previously with the wide scrollbar, go to “Menu / Settings / Appearance / Themes” and at the bottom click “Import Theme” and select your saved theme from whenever you previously saved it on your hard disk folder as per the screenshot example further down.
Or if you haven’t ever saved your own custom Theme, then just “choose one of the other built-in themes” and click “apply” and save settings. Then go back to settings and change back to your original Theme and then click “apply” and save settings and should be back to normal.
You can also “optionally download and import user created Themes” via this link if you want different Themes.
If you want to use a widen the scrollbar see the following post from @Gary below.
If you want to modify a Theme and need help, see the following eM Client blog “Design your own Theme” and also the online Documentation.
Found the Themes and downloaded one more to my liking.
