eM Client Behaving Strange
I am not sure what’s wrong. Either something might have gone wrong during the installation or may be after the installation.
Right now, eM Client is giving strange results. I am using Win XP SP3.
  • Although I have set it as default client but its still showing as not default.
  • As reported in the other topic over here https://discourse.emclient.com/emclient/to…, only one Contact List is showing for a Gmail account.
  • In Accounts, Calendar and Contacts & Chat tabs are missing for a another Gmail account.
  • Any changes I make in the settings do not get saved.
  • When I opened the program again, it was giving a message that program was not closed correctly and then it took another 15 mins to check and repair.
  • After this, for a specific Gmail account, the messages were not synced.
I was seriously thinking of purchasing this but now confused.
As per this reply https://discourse.emclient.com/emclient/to…, I was able to fix a few issues but not all.
On the other hand, I am evaluating Postbox which is a closer match of Thunderbird and is working perfectly fine.
I am still unsure why eM Client is giving undesired results.
Can I ask you with what exactly this reply helped you with? I understand that I was trying to solve your issue in that topic, but I will need list with issues you need still to resolve.
regards
Jan
Hi John,
Lets start with this first:-
  • Any changes I make in the settings do not get saved. I tried uninstalling and reinstalling several times but the problem some how seems to occur.
Thanks,
Alok
What version of eM Client do you use?
Ver 5.0.18661.0
Please email me on Monday at [email protected] - I will send you further instructions.
Hi George,
I will open a support ticket on this and list all the issues in detail. It will be easier to track.
Thanks,
Alok
