I’m trying to syncronise eM Client with fruux Contacts and Calendar but it won’t let me due to “please enter valid email address” in the account setup. I’m following the steps on fruux.com and I have a username which is not an e-mail address. Any suggestions?
you want to use Fruux cal and cardDAV only? If so do you use Automatic setup by any chance?
That will not work, you have to use in New Account dialog - Calendar “Fruux” and after you will finish with it then in “accounts” window under you account there should be option to enable contacts too (or you can add it same way as you have done with calendar)
Jan
thanks for your answer. I didn’t use the Automatic setup. But yesterday I tryied the Beta version and it works, so I guess I’ll just leave it this way.
Vlad
ok, thank you for your update on your issue.
Jan
