In emClient 6 (and pretty much all text editors I use) I frequently add HTML links to my text. Conventionally, you select your text and use CTRL+K, then paste in your link.
It seems that emClient 7 no longer supports this keyboard shortcut and you have to manually use the mouse or otherwise navigate menus in order to Insert / Link.
I also cannot find a relevant entry in the options for shortcuts to manually add this. Am I missing something? If not, can you please add back this extremely standard and expected feature?
