Hello. Could you please post here a screenshot how it looks? Thanks.
The order of the fields is not correct when I add an appointment and go with the TAB key to the next field
As a see now it’s not a paragraph margin. Instead, the line hight at all has been inreased to about 1.4 lines. Hard to read, though.
I use a lot of very long notes in tasks. The new line height makes my notes double that long (scroll baby, scroll). The line gap is by far to wide.
I’m having an issue with the Calendar (was already present in beta 1):
- I had once set up a recurrent event (every 5 weeks),
- the event duration is 5 minutes
- for some reason, I want to edit the next occurrence (and only this one) to change its date, so I choose “Open this occurrence” and change the day,
- the event is correctly moved to the new date, but the event duration was unexpectedly modified to become 1 hour (actually the end time wasn’t touched, but start time was modified to end up in a 1 hr duration)
The same issue was observed when moving event with the mouse (this is the same operation actually, so just for completeness)
This is pretty annoying issue, mainly when you use to modify/move events quite a bit.
Thanks in advance.
Outlook.com: No tasks?
Syncing outlook.com is easy, but why don’t I get the tasks while calendars are available?
Confirmed. Tab index is wrong.
I ́m not able to copy a text or numbers from an email to word, excel or an appointment by click STRG+C/STRG+V or right click. it will not be written to the clipboard
just a minor issue - when minimizing the program to the taskbar while the program window had been maximized, upon clicking on the taskbar icon to resume working in the program, the window is no longer maximized to the whole screen.
I have the same problem - but only for appointments that were already present before the update to beta 6.1. If I will open this appointment min from a length of 15, a length of 60 min. At the same time the beginning of eg 14 clock is moved to 12:15 clock.
But the problem does not occur with new appointments and not for appointments that I have already changed to the current time zone and the correct length
Minor request: I think it would be useful to configure the system to ask or by setting include or not attachments in replies.
If I receive an email with some pics and I want to say thanks, I don’t want to send pics back to the sender.
The system could ask me or I’d like to configure this in the setting or (maybe) a flag in the reply window to include attachments or not.
Thanks
Good point. “Do you want to include all images/attachments in the reply/forwarded message?” [x] Don’t ask me again.
That would help those that do not know what they do to save receivers mail quota.
Or save my own 3G quota
Thanks
Seriuosly… I think that question box after a click are not good…
I would prefer a global settings in order to give the application a default way (include attachments in reply/forward) and then in the reply/forward mail windows a checkbox (by default activated or not based on my choice in the settings) that I can use to include/exclude attachments for the mail I’m writing.
So I can also change my mind later before pushing SEND.
I just have to click on the checkbox…
You are right, this issue has already been fixed
Well, setting an option for an option/check box to appear…
Lockig at it the other way round would be an Action menu entry and/or icon “remove legacy images/attachments” or so.
See this behaviour in 6.0.19404. Are you talking about beta 3 (past 6.0.19404)?
I would keep the checkbox in the mail window (the one used to write/reply I mean) permanently so I can add/discard all the attachments with one click… the config setting it’s just to change the default behaviour of the system to include/exclude attachments.
At least this is not a beta fix issue. Request should be moved to vote forum.
