eM Client 11 on macOS attempts to load remote email resources in the background despite privacy settings
After updating to eM Client 11.0.1054 on macOS, I started receiving repeated Little Snitch alerts about eM Client attempting to connect to external websites.
These attempts occur while I am not opening emails or clicking “Download pictures”. The application appears to be processing or reindexing existing messages after the upgrade, although I have not confirmed whether indexing is the trigger.
My relevant settings are:
• External email content is set to “Block external content”.
• “Download avatars from external sources” is disabled.
• Avatars in the message list are disabled.
• The affected senders are not on my Safe Senders list. The exception allowing content from safe senders therefore does not explain these attempts.
Little Snitch shows connection attempts to domains such as:
cdn-images.mailchimp. com
cdn.sender. net
assets.gumroad. com
b.stripecdn. com
click.ashbymail. com
clicks.hostinger. com
d3vhsxl1pwzf0p.cloudfront. net
dgk28ckagqims.cloudfront. net
claude. ai
These appear to be remote resources associated with email content, including newsletter images and tracking or redirect domains, rather than connections needed to synchronize my mail accounts.
Could this be a regression in the updated Chromium-based HTML rendering engine in version 11? My concern is that a background processing or rendering path may be initiating requests for external resources without applying the email privacy settings.
If messages are being processed for indexing, previews, or Spotlight integration, that should not cause the application to fetch remote images or contact domains embedded in those messages. The external-content restrictions should apply to background processing as well as the visible message view.
Hi @sampling294 thank you for this report, even eM Client’s background processes should of course, respect your privacy settings inside the app. None of our own indexing or preview loading loads external content.
To figure out what could possibly cause this, we will need to troubleshoot a bit more, though.
If you temporarily block eM Client from Spotlight search in system settings, does this keep happening?
What version of macOS are you using?
Thank you.
Yes, after disabling Spotlight indexing, the error still occurs. Newly received messages—even unopened ones—cause queries to domains such as fonts.google.com while the app is in the background.
26.7.1 (25G241)
Hi @sampling294,
Thank you for the extra details, and for testing with Spotlight disabled. That helped narrow it down a little.
I’ve discussed this behavior with our devs and they’ve now checked every part of eM Client that handles a message when it arrives: notifications, rules, search indexing, classification and avatar lookup. None of them should load remote content from the message body while blocking is enabled.
We’d still like to find out exactly what is making these requests, of course, so could you help us with a few more details?
  1. What kind of events you’re seeing. Are these DNS lookups only, or actual connections (TCP/HTTPS)? A screenshot of the Little Snitch entry, or its connection details, would be ideal.
  2. Which process the traffic belongs to. Does Little Snitch attribute it directly to eM Client, or to a helper or system process acting on its behalf? On Windows, which tool are you using, and which process does it show?
  3. A sample message. Could you save one of the messages that triggers it (for example the Stripe or Mailchimp one) as an .eml file and send it to us privately? Select the message and choose right/click (or File) > Save As. Then we can reproduce it here under a network monitor.
  4. Security software. Do you have any antivirus or security software that scans incoming email or checks links (for example email protection or web shield features)? Those tools often resolve links found in messages in the background, and the traffic can look like it comes from the email client.
Send all the information and example message to [email protected] with a link to this forum thread in the body, please.
Once we have this, we can tell whether the requests come from eM Client itself or from something else on the system. If it turns out to be eM Client, we’ll treat it as a privacy bug and fix it.
Thank you for your patience and cooperation.
