Suggest you “close eM Client” and then go to the following hidden database folder and “rename it” to eg: eM Client-Old.
“Hidden mail database folder Windows”
Then uninstall eM Client and after the uninstall then if the following folder still exists “delete it”, “C:\Program Files (x86)\eM Client.
Then reboot your computer and then reinstall the same eM Client version 10.4.5674 either from the release history page or Windows store depending on where you originally installed it from.
Then after reinstalling if you have been making regular eM Client backups open eM Client and “Skip the setup wizard” and restore your backup via “Menu / File / Restore”.
Or if you don’t have any eM Client backups, setup via the wizard as new.
If you then have an IMAP, Exchange, Office 365 or iCloud account all your emails, contacts, tasks etc will come back from the server end.
Note: If you have a POP account or messages in Local Folders then if you do manage to get into eM Client “export your emails, contacts, tasks etc” first to a folder on your desktop before you rename your database and uninstall eM Client via “Menu / File / Export” so you can then import them later after reinstalling via “Menu / File / Import”
The file ‘fill5ewrsRX1kbl9Hc.PLEvytBBeko’ cannot be installed because the file cannot be found in cabinet file ‘MailClient.cab’.
If you still have problems after uninstalling and reinstalling with eM Client files that cannot be found etc and have Windows 10 or 11, then uninstall eM Client again and “delete the new database” when asked in the uninstall wizard.
Then “clear all your Windows temp files” which can sometimes be the cause of that type of error,
Then try running the Microsoft installer / uninstaller troubleshooting tool below which still appears to work on Windows 11 as well even though is not stated.
Note: If you do run the Microsoft tool, “reboot your computer” before trying to reinstall eM Client.
“How do I Fix problems that block programs from being installed or removed”.
https://support.microsoft.com/en-us/topic/fix-problems-that-block-programs-from-being-installed-or-removed-cca7d1b6-65a9-3d98-426b-e9f927e1eb4d
