wie kann ich emClient unter Win10 auf neuem PC einrichten?
The best way to ensure all your data and settings are brought over is through Backup and Restore.
Steps and tips are as follows:
In the old device:
Create a backup through Menu>File>Backup
Deactivate your license if you are no longer going to use eM Client on this device in Menu>Help>License
- not needed for one-seat licenses, but useful for making sure no licensing problems happen
Find the .ZIP backup file and move it to your new device (default in …\Documents\eM Client)
In your new device: -
Install eM Client (http://www.emclient.com/download)
Skip initial setup
Restore from your backup through Menu>File>Restore
Activate your license in Menu>Help>License
If you put the backup file in the new device in the same folder structure as the default (…\Documents\eM Client) the restore will find it right away, otherwise, you’ll need to specify the path where the backup file can be found.
Copied from the Knowledgebase.
