Duplicate messages in Favorites with 11 beta
Ever since I linked two PCs to the same account —a new feature in em11 eM sync—messages appear duplicated in all the favorites lists.
Actually, I’ve taken a closer look. All the folders for my accounts are duplicated.
This happens on both PCs. It is very annoying.
How can I prevent this? Where am I going wrong?
Do you have the account added twice in both devices now, perhaps? (By synchronizing and adding the same account to the eM Sync account each time?)
You should be able to manage your accounts in Menu > Accounts
Which accounts are synced via eM Sync is set in Settings > General > eM Sync.
Can you check if you have your email account only once in both of these places?
Thanks for the reply. It actually created duplicate accounts for me. I had a really hard time cleaning them up. In some cases, they even disappeared from the eM Client backup; fortunately, I had my own backup. I seem to have everything sorted out on the first PC now. Tomorrow I’ll check the second one I have at the office. Fingers crossed…
I don’t know why it duplicated them and then—in some instances—even deleted them.
Can you perhaps provide more exact steps/order this happened in to [email protected]?
Because eM Sync does not add or create new email accounts in your eM Sync account automatically, but if perhaps this happened in some specific order when you installed BETA on both devices we’d of course want to analyze this and try to find a way to avoid this behavior.
Information that might help us is for example:
Did you add/sign into the eM Sync account during the initial setup, or in Settings later?
Does the account that was duplicated have different settings on each device or are all tabs in Accounts window the same?
Thank you for your cooperation.
