Is it possible to add this feature to eM Client? I would like to use two reminders for some calendar appointments/events. Like one reminder a day before and one reminder an hour before.
You can “snooze” reminders for a variable amount of time which you can select from a dropdown menu when snoozing. So for example you can set up a reminder 1 day before and then snooze it for 12 hours so it will come back 12 hours late.
Hope that helps.
Dave
Yeah, I suppose that’s basically the same thing just going about it a different way. Thanks!
