Bonjour,
J’ai le message suivant : "Aucun dossier de programmation par défaut pour le compte XXXX n’a été défini, veuillez en sélectionner un.
Capture d’écran 2026-10-30 à 13.44.04|407x157
Qu’est ce ?
Bonjour,
Qu’est ce ?
I’m getting the following message: "No default programming folder has been set for account XXXX, please select one.
That could relate to your Calendar section of eM Client either with “No Account Calendar selected”, or “No Local Folders Calendar selected” as in the first example screenshot below that has a Yahoo Accounts Calendar selected and a Local Folders Calendar selected.
So if you are are running a Local Folders Calendar and don’t see Local Folders in the Calendar section, then go to “Menu / Settings / General / Folders” and click Local Folders and Save & Close as per the second screenshot V10 example below.
Merci beaucoup ! Je vais cocher "dossiers locaux ! ".
