What are settings for att.net email. All my other emails work fine. Cannot get att to work
Hi, did you use the automatic setup for setting up that account?
After a quick search I’ve found the following setup for this provider:
POP
HOST: inbound.att.net
PORT: 995
Security policy: Use SSL/TLS on special port (Legacy)
SMTP
HOST: outbound.att.net
PORT: 465
I hope this helps,
Still not working
It works fine with the settings above and “use identity credentials”. Thank you!
Hi, can you make a screenshot of your current settings? Are you using identity credentials? Are you receiving any error messages?
Great! I’m glad the above setup has worked, if you come across any other issues or have any questions about the application, let us know, we’ll be happy to help.
