Waht DNS Settings do I need to enter into 123-reg please? I have another domain name that runs happily on a different email client but had to have the DNS settings set up inside 123-reg first.
You can try using the automatic setup for your email account. If that does not work, then you can do it manually. Your provider should be able to give you the host name for the server.
