Is there a toolbar button with a drop down list of the names of your distribution lists or a way to create one? Obviously, a lot of people are having trouble finding the distribution lists among all their contacts.
Hello, unfortunately it is not possible to select a distribution list from a dropdown, eM Client currently does not include this feature. Distribution lists are saved within your Contacts folder that you can search through. Or by starting to type the distribution lists name, then it should be automatically suggested by the autocomplete feature.
