I’m trying to create a distribution list by clicking the “new” tab when I’m in Contacts. But all I can do is add a new contact. Thanks.
If you click the down arrow in the New button, it should give you the option. The shortcut is Ctrl+Shift+N from anywhere in eM Client, if that helps.
Thanks Gary! All working well now.
