Disappearing attachments?
When I receive an email with attachments, the attachment file name is visible when I first select the email, but then disappears. If you right click in the attachment box and select open all attachments, the attachments open even though they are not visible. Unless you notice the attachment when you first select the email, you won’t know there is one.
please download and install this http://www.emclient.com/dist/v5.0.176… if it doesn’t solve your problem
Solved! Thanks for the amazing quick solution!
