I’m sure there is a logical explanation for this, but I’ve just noticed our office PC’s are on version 7.2.5008 and our office laptop is on version 9.2.1735 - there are no updates available for any of the machines when you prompt for the update.
There were differences in some of the settings menus which is why I noticed.
How is it possible for two office computers to be on two different versions then?
One may have missed an official update at some point and then maybe got stuck checking again for updates. Or might have possibly been a bug and the checking for update automatically didn’t popup.
Anyway to get eM Client V7.x for PC up to the latest V9.x, you can do that via the Release History Page. What i would suggest is to first update to the latest V8.2.1721 , and then update to latest V9.2.1735 . Close eM Client before updating.
Also if your eM Client V7.x is a Pro version then there may be a cost involved upgrading depending on the version you bought at the time. If it was a free non pro version and you don’t use it for business use, then will be no cost. So just to be aware of that when you are upgrading incase you have Pro version.
Also backup eM Client before you upgrade incase you need to restore for any reason. In version 7, do that via “Menu / File / Backup” which creates a backup .zip file in your Documents / eM Client folder.
