Dictation Voice Typing - needs help
MS Windows 10 and 11 has Voice Typing by pressing the Windows button and H key. A small window comes up where you can dictate your content. This sort-of works on eM Client but it does not capitalize the letters in new sentences and has some other glitches.
I recommend the team at eM Client try to fine tune the use of Windows Voice to Type.
I use it all the time because it allows me to articulate more on my e-mails without the need for typing. Only thing is that then I need to go back and delete the extra spaces before periods, add two spaces after the period and capitalize the letter in the subsequent sentence.
Do other mail clients also have the same problems or is this only with eM Client?
Microsoft Outlook, being a Microsoft product I suppose, does work well. The downside is that it’s Microsoft Outlook, which if anyone is using emClient knows that Outlook is absolutely terrible.
