Hi All,
I have quite stressful situation.
I use the profile manager from EmClient with 2 profiles to switch between.
When I wanted to delete profile number 2, and I select delete files, it also deleted profile 1.
So all my mail is gone.
Is there a way I can retrieve it from a trash/bin?
I’m using a Mac
I had a backup from about a year ago, so not very recent…
The thing is that I had my email data from the profiles in separate folders which are in the the same folder, so :
user data1 : volume name/user/documents/emclient data/user 1/…
user data 2 : volume name/user/documents/emclient data/user 2/…
So when I deleted user 2 (including data from that profile using the profile manager) it not only erased user 2 but also user 1 and also the ‘emclient data’ folder???
So all was gone.
And does emclient erase like final erase the data from the drive?
Mostly when something is erased it ends up in the trash folder…
Normally deleting a second profile “from within eM Client” doesn’t delete anything from the first profile “as long as the profiles were setup in separate folders” which looks like you did.
However if you also manually deleted the second profile database outside of the program “if that’s what you did” that might have possibly caused your first profile data to also dissapear as might still be connected in someway within the program.
What Mac version of eM Client is this ?
Was this a POP, IMAP, Exchange, Office 365 or iCloud account ?
Also did you have data in Local Folders for the second Profile ?
